So I tackled this task today...... Was it worth it? Read on....
So any mod has a risk / reward factor. In this case I'm gaining filtration, at the risk of a hose popping off or other issue with fluid leaks.
It started well, used my tiny cutter to take out 6" of hardline. ( The Magnefine filter is 5", tip to tip)
Then I hooked up some hoses and started the car, to confirm which way the fluid is flowing
Without question, on a 2020 Traverse, the UPPER hardline, is the RETURN line.
The Magnefine filter must be installed correctly in the direction of flow. There is a bypass feature inside, so if the element ever clogs, the bypass will open and fluid will continue to flow. If the Magnefine is installed "backwards", this feature will be eliminated.
So then came what I thought was the easy part. Simple flare job on the hardlines, a few clamps, and I'm done....right?
Wrong. These hardlines are tough! I was going to do a small double flare , which looks like this, but about 1/2 the size. The purpose is to keep the rubber hose from sliding off.
Well, with the confines of what I had to work with, this just didn't happen, which brings me back to my original comment between risk and reward. I didn't want to just leave the hardlines bare, so I did a little single flare. It looks like this.... Not what I wanted, but better than nothing.
Because I only could get a small single flare, I double clamped everything, and here's the finished install.
I'm trying to figure out if this was a waste of time, or not..... so I pull the magnetic drain plug for a look. It has been doing it's job for 8,000 miles / 4 months. Dang! That's allot of crap!
