How to change second row captains chairs to a bench seat
37K views 4 replies 4 participants last post by  acastillo7609
#1 ·
We found ourselves needing a little extra room for car seats in our 2015 Traverse LT with second row captains chairs. I stumbled across the post which discussed the opposite swap and found the encouragement I needed to take this on. I picked up a bench seat, seat bolts and trim pieces from a 2014 Traverse in excellent condition from a salvage yard for $200. Basic steps and pictures below.
1. Obtain a bench seat (60 and 40 sides), a few extra seat bolts, and the appropriate plastic trim.
2. Remove the plastic trim pieces around the seat tracks.
3. Remove the bolts holding each seat in place. I used an air ratchet/impact wrench.
4. Remove the captains chairs. Get help from a buddy so you don't hurt yourself or the car.
5. Install the passenger side (40) seat. Start the bolts on the passenger side seat track, do not tighten. Do not install the driver side seat track bolts yet.
6. Put the driver’s side (60) seat in position and align the holes. You will notice that one of the right rear seat track mounting pads does not have access to a hole because it is covered by carpet. Trace the seat track on the carpet with easy to remove chalk.
7. Remove the driver’s side (60) seat.
8. Cut a small portion of carpet around the seat track mounting pad. You have now exposed a bolt that will need to be removed.
9. The walkway between the captains chairs has a thick foam support, I chose to cut this out below the carpet where the new seat track runs front to back to allow the seat to sit flush. I did not cut the carpet for this, only the foam.
10. Install the driver’s side (60) seat and align the holes. Install bolts in all locations. Note that the right side mounting pads of the driver’s side (60) seat will install on top of the left side passenger side (40) seat.
11. Take a break, grab a beverage.
12. You will notice two carpet voids on the driver’s side where the old seat track was installed. After installing bolts in the unused holes, I covered the voids with sticky back mass loaded vinyl (sound deadening material). I then cut out heavy foam in the shape of the holes to level the spot with the surrounding carpet. Finally, I cut and installed a piece of black carpet to cover everything up.
13. Install the plastic seat track trim pieces.
14. Enjoy.
We are keeping our captains chairs so that we can revert back when our kids are older.
#3 ·
Hey b85chevy, sorry for the 1.5 year necro-post... thank you so much for the info - my wife and I want to do the EXACT same thing to our 2015 Traverse! We went to the body shop to have them do it and they told us that the seat belts have air bag sensors in them and it would set off the airbag light on our dash if we switched from captains to bench - there are two seat belts for the captain chairs, but three seat belts for the bench. Did you run into any airbag issues/lights, and did the bench have a harness that needed to be plugged in for the airbag sensors, etc.? No issues/lights/airbag items at all? Thanks in advance if you get this post.
#4 ·
I just changed out 1 of my seat belt buckles in my 2nd row bench seat. (the part with the red button)... as the case broke.
There was NO electrical wires going to this buckle.
Simply look at your 3 buckles and see if a wire is coming out of it.
I doubt the 2015s have sensors for the rear buckles.
I believe its the new 2017 Acadias that have some sort of rear passenger reminder--- so parents dont leave kids in rear seats.
