i had just finished up replacing my primary wiring harness after suspecting a bad wire to be the cause of my no start condition but now with the "new" harness in place it still wont start and the there's a weird buzzing noise coming from the fuse box when i try to start the car. i pulled all the fuses and they all appeared to be fine, don't know how to check the relays though. the buzzing stopped when i pulled the PWR/TRN relay so i swapped it with a relay of the same part number of the fan ports (1,2 and 3) none of them made the issue go away so i think its not the relay but idk for sure.
