I need to change my ECM, are there any relearn procedures or data that needs to be transferred from the old one to the new one?
I honestly have no idea, there could be all kinds of issues. The part is new so it won't have another vehicles info in it but it won't have mine either.rbarrios said:I wonder if this requires the dealer to program the vehicles VIN into it.
I took it to the dealer for the throttle body issue everyone has and they determined it was the ECM after replacing the throttle body under warranty.someone said:Curious, how have you come to the conclusion that you need to replace the ECM?
Well, I thougt it might be worth a tryFat Brian said:It's a 2011 LTZ with 99,700 miles, I over shot the ECM warranty by a good bit.
Was the ECM working with the old throttle body, if so the dealer should be able to reprogram the old ECM to the new throttle body without replacing it, provided he is using the latest programming software.Fat Brian said:I need to change my ECM, are there any relearn procedures or data that needs to be transferred from the old one to the new one?
First time I have ever heard to replace the accelerator pedal! What is the thinking behind this suggestion? I don't recall anyone with these vehicles having any problems with the accelerator pedal, only the brake switch module by the pedal.someone said:ECMs rarely go bad. Usually what are diagnosed as ECM problems are actually something else like water in a wireing harness or a loose connection. If you are having throttle body codes and changing the throttle body didn't fix it I would suggest changing the accelerator petal.
Interesting information. Like I said though, I don't ever recall anyone with these vehicles having a bad gas pedal module. Perhaps this is the first? Hopefully the OP keeps us up to date with what the problem turns out to have been.someone said:The ecm takes a signal "resistance" from the petal and moves the throttle body accordingly. Just a theory, but the petal may be sending a faulty signal causing the ecm to do erratic things with the throttle body, and the ecm is seeing it as an error with the throttle body.
At work we are running about 15 chevy 2500 with the 6.6 duramax all ranging from 2008 to 2015. Some with well over 300000 miles. We have changed maybe 3 petals, so not a common problem, but i do remember when it happens we were getting reduced engine power, and a code that had absolutely nothing to do with the petal. I know your vehicle isnt a 2500, or diesel for that matter, but i do know ecm problems are very rare, and are often another problem that has been misdiagnosed. For kicks, call a parts department at a chevy dealership and see if they have any petals in stock. If they do then its a safe bet that they go bad. It would be an odd item to stock otherwise
It gave all of the symptoms of the Stabilitrak error the throttle body gives, suddenly going into limp mode, traction control off on the DIC, everything. The only difference was my car was actually cutting completely off and the starter wouldn't always fire when you turned the key after it shut off. It happened the first time in September and I took it to the dealer and they said the ECM was bad but they had given me such a run around about doing my power steering pump I wasn't inclined to believe them. I took it home and cleaned the throttle body and it ran fine for almost two months then it did it again. In between the two occurancres the warranty on the throttle body was extended so I took it back to a different dealer and had the throttle body replaced, on the way home it quit again. I towed it home and found a new Delco ECM for $100 on eBay and replaced the busted and towed it back to the dealer to have it reprogrammed, I saved myself over $500 and uit runs like a new car now. The ECM is that silver box hanging on the fan shroud, it snaps in it's little holder with no bolts. I changed it under 5 minutes.Thomcat said:Was the ECM working with the old throttle bod... ...Sounds like an expensive repair.
someone said:Strictly a theory. Like i said, i would call several dealerships and see if the petal is a commonly stocked item.
Were you having the issue with stabilitrack and traction control? I am bringing into dealer on Monday for that problem. if so what did you do? I am out of warranty.Fat Brian said:It gave all of the symptoms of the Stabilitrak error the throttle body gives, suddenly going into limp mode, traction control off on the DIC, everything. The only difference was my car was actually cutting completely off and the starter wouldn't always fire when you turned the key after it shut off. It happened the first time in September and I took it to the dealer and they said the ECM was bad but they had given me such a run around about doing my power steering pump I wasn't inclined to believe them. I took it home and cleaned the throttle body and it ran fine for almost two months then it did it again. In between the two occurancres the warranty on the throttle body was extended so I took it back to a different dealer and had the throttle body replaced, on the way home it quit again. I towed it home and found a new Delco ECM for $100 on eBay and replaced the busted and towed it back to the dealer to have it reprogrammed, I saved myself over $500 and uit runs like a new car now. The ECM is that silver box hanging on the fan shroud, it snaps in it's little holder with no bolts. I changed it under 5 minutes.
jagincal said:Were you having the issue with stabilitrack and traction control? I am bringing into dealer on Monday for that problem. if so what did you do? I am out of warranty.
John
It is FWD. I will find out more from dealer today. They are replacing battery for another issue.rbarrios said:the stabilitrack and traction control messages--- theres many things that can make those messages pop up.
Non related things.
Even low battery.
is yours FWD or AWD?
