Of course 'oil and filter' is the most common maintenance item one does on an vehicle. Just trying to get an idea what we Traverse owners do in this respect.
For this car, for the past several changes, I have been bringing it to a one man shop where I supply the oil and filter and help in the process. I do get receipts. But I think I will go back to doing it myself starting with the good weather as this past fall the drain bolt was replaced with a FUMOTO valve which will make the process much easier i.e quicker, safer and less messy.
But I am a bit torn as the advantage I see of having it on the lift when doing regular oil changes is one can at the same time do a pretty detailed visual inspection of the undercarriage and such and so might see, for example....any fluid leaks. The mechanic I go to has no problem with me going under the car while it is on the hoist and poking around.
