I have a 2012 traverse LS and recently began having an issue where the rear drivers side window will not go up from the drivers console. The window will go down from there but not up, all other windows work as they should. The rear window switch operates normal up and down. I tried replacing the drivers side panel with a new switch and have the same issue. I also swapped the rear drivers switch with the rear passenger switch and all work as they should. I am now at a loss as I figured it would have been the drivers switch. Someone please help!!!!!
this happens for the passenger side for me. Doesnt want to work from the driver side switch. i uually take it apart and clean off the connectors and contacts.
See post #8 here for how to clean:
https://www.traverseforum.com/6-general-discussion/5981-power-windows-won-t-go-up.html
