My wife used her key fob to go thru the menus and set things up the way she wants them. A couple days later, I went thru w/ my key fob and did the same thing. The problem is that some of the things I changed were also changed on her profile!
For example, she prefers the Touring setting on the instrument cluster, while I prefer Sport. But when she got back in the vehicle, it was still on Sport. And when I got in, my radio station presets were correct. But it was still tuned into the last station that she was listening to. I haven't looked at things like lane change alerts and adaptive cruise control, but I hope those switch properly w/ each profile. Expecting the vehicle to behave a certain way and then it behaves in a different way while driving is a serious safety hazard.
Also, while playing around w/ the settings, it somehow got stuck in the instrument cluster menu. I've changed the things I want to change, but the menu itself won't close. The manual tells u several times how to access the menu (hold down the center check mark button on the right button pad on the steering wheel), but never how to get out of it! I tried holding that button again, but that doesn't work. And there's no exit button or exit setting on the screen to select. Turning the vehicle off and restarting it doesn't work either.
