Hi there,
I have a 2010 traverse and yesterday I went to use the washer fluid and noticed the pressure on the drivers side is very low. The passenger side works fine but the drivers side is only hitting the bottom of my windshield. Does anyone know of a solution for this? I'm not sure of where to look if its kinked or something.
Thanks!
Leaky washer fluid hose on the driver side or partially clogged nozzle. Follow the hose to check for leak or clean the nozzle with a pin if necessary.
Check for kinks in the hose.
It runs right past the air cleaner and IIRC, some folks have reported squeezing the hose between the upper and lower halves of the air cleaner.
yeah. check that cover on the filter- especially if the air filter was recently checked.
You may also want to take a needle and gently poke the nozzle... could have buildup
