Is your Traverse dying out of the blue? Will not restart, wont crank, just dashlights and a rapidly flashing CEL upon turnIng the key?
Dont buy a new alternator, PCM, ignition or battery..
CHECK THIS FIRST..
Ive fixed 3 Traverses 2009-2010 by doing this.. it is a bad ground. The wiring harness ground on the passenger side corrodes and you lose ground to the PCM. Causing intermittent loss of power.
When you have the issue wiggle and pull on the wire harness pictured. If the problem quits youve found your issue. You need to replace the terminal that grounds the harness. Maybe a 5.00 repair. OR in some cases the bolt (10mm ratcheting box end)
may have just loosened. It may be a good idea if you take it out to put some thread locker on it.
I should add the possibility of a bad wire in the harness as well but youve narrowed your issue down to a location..
I hope this helps as ive seen a lot of frustration over the issue. Good luck!
Please take the time to reply if this worked for you and help others.. thank you!!
CHECK THIS FIRST..
