2014 Chevrolet Traverse
When I drive the traverse and get to about 15-30mph speed, it tends to shake as if it was running out of fuel and is losing power. I have to gas it to pump more fuel which tends to help it. It never actually turns off or stops, just shakes. This also happens at higher speeds when driving, doesn't necessarily happen when shifting, so I do not think that it is the transmission. Also, the traverse is now randomly not starting when turning the ignition, just clicks when turning the key to on. When this happens, I pump the gas pedal to help it get started. Most of the time it starts right away, but sometimes it sounds like it is struggling to get fuel before it starts.
Seems to me it is a fuel system problem, fuel injector, ignition switch, fuel pump, but not sure. Any advise on how to troubleshoot or pin-point the problem?
