I don't know if anyone makes a "Bra" yet but after having both on cars and pickups I think the best thing is to get both. The bra's ok on highway trips but bad for everyday use. If you keep a bra on for daily use dirt builds up under the upper edges and if you don't constantly clean it, it will "sand" down your paint. Which brings another problem with a bra. Since it is nice soft material behind the vinyl it holds moisture and is tough on the paint and any welded areas like the underside of the hood edge. So having the chipguard on will help protect against most debris and also keep the bra from cutting into your paint when you use it . This is just my experience, hope it helps
