1. I hv 2010 trav....recently I hv replaced coolant, thermostat, coolant sensor and water pump from petromin with gen parts.
2. My car temp needle goes little up while in traffic or at idle even if I stay for a minute but when I start driving, needle comes down to center.
3. No leakage and coolant is at full mark in cold position and full in radiator too.
4. I hv observed that I drove for 10.minutes and ac not running, but first fan did not run, but needle was at center....so should it has to run or when the first fan is to run?
5. Someone told me to check relays first, so which relays and how can I check?
6. When I start ac the both fans turns ON but I doubt the speed which seems to be low....
7. Pl advise....
7. Pl advise....
