1 - 3 of 3 Posts
I have a 2010 Chevy Traverse and within the last couple of weeks the traction control and abs lights have come on. I noticed a vibration in the brake pedal and it sounds like the brakes shutter when applied, once the traction control and abs lights come on the shuttering goes away and it seems to break fine. But the information center says my awd, stabilitrak and traction control are off. All the wheel speed sensors have been replaced, any ideas of what's causing these issues?
Discussion Starter #2
Found the issue was a bad magnetic ring on one if the wheel bearings. Simple fix, replaced the wheel bearing.
thanks for the update.
1 - 3 of 3 Posts
