1 - 12 of 12 Posts
I have a 2018 Traverse LT. The vehicle model I have does not have the V92 yow hitch package which online states is just a hitch and a heavy duty transmission cooler. The chevy dealer had a hitch installed but said that the transmission cooler couldn't be added after factory (voids warranty).
Without the tow package, my traverse is only cleared to tow 1500 lbs. If the v92 package were installed, which appears to only be a tranny cooler, I could tow up to 5000lb. Im wondering if I had an after market transmission cooler added, would that really bump my towing capacity from 1500 lb to 5000lb?
It would possibly give you the confidence that you could tow up to 5000 lbs, but the vehicle would still be rated at 1500 lbs, as per the sticker on the driver's door. Additionally, you would set yourself up for a voided warranty if ever you had a drive train issue. I'm not certain, but I believe others have commented that there are some programming changes in the engine and transmission control modules that are also affected with the towing package, along with stability control/traction control.
Personally, I wouldn't tow 5000 lbs with a Traverse even with the tow package from the factory. It's a unibody vehicle (no separate frame) and won't handle the stress as a pickup or Suburban will, particularly if it's a FWD and the tongue weight is lifting the Traverse's nose and transferring weight drom the driven wheels. My opinion, it's a bad compromise to tow at that weight.
I'll second not to use a traverse to tow near the max rating. I've got a Tahoe also and a full frame vehicle is needed to tow 5k , most I would put on my Traverse is 3500 lbs. It's got enough motor but that Unibody would be getting a big work out especially how tow receiver mounts.
I added an aux oil cooler and towed a 4000 lb camper. I wasn't happy. Bought a 1/2 ton pickup truck and it was a LOT better. Popups and A-liners only with the Traverse, IMHO. You don't want to pull a sail down the highway with a Traverse.
But if you insist, PM me your email address and I can send you info about adding the V92 package.
I've towed my 6x6x12 single axle V nose trailer with mine and it tows just fine. 14 mpg over a 500 mile round trip in 2wd mode. Empty weight is 1500 lbs. . Towed just like it was on my Tahoe.
Hi Everyone, I have the same question. I have a 2018 Traverse and it sounds as the V92 package biggest upgrade is the larger radiator with transmission cooler.
Users that have hauled heavy with their traverse, Did you have the tow package?
I am looking to haul approx. 4000# but would obviously need to upgrade the radiator etc..
I wonder if there are any transmission differences. I am going to the dealer on Wednesday to discuss.
Any input is helpful. Thanks!
IMO, cooling the transmission is a huge part of towing to maintain a certain temperature to prevent the trans from overheating that can cause premature life span or failure if you drive through the mountains or steep hills above 1500 lbs. Heat kills. Don't forget about brakes in that same terrain, slippage and soft brakes around those skinny mountain roads can be scary with good brakes and not towing anything... Personally, I wouldn't tow without a cooler, that me though...
I have a 99 modded Camaro SS and installed a high stall TC and the first step I did was installed a trans cooler to help dissipate the heat generated by the TC to save my trans.
Did you read my Post #4? If what you're pulling is a large sail, I'd get a pickup truck with more capacity than 5000 lbs.
2x
At the 4k level it's pickup or Tahoe.
Greentraverse has experience.
I have the 2018 Traverse LT with the tow package pulling a 4000lb dry weight dual axle travel trailer (4500lb loaded) with a weight-distributing hitch. I use the Curt Echo Bluetooth brake controller (wireless) and get 14mpg overall at 60 mph. Hardly know the trailer is back there it pulls so smoothly. The trans temp rises to 200 degrees Fahrenheit when towing in hot weather and hills (normally ~170 degrees).
In addition to the trans cooler, I would expect engine and transmission calibration changes in normal and tow mode are included with the tow package. Not sure if you have the tow mode selection without the tow hitch option.
Good Luck.
9647
Tow mode selection is only available when you have the tow option.
Reactions: snobrdrdan
1 - 12 of 12 Posts
