Hi Everyone,
I've recently started having problems with my '09 Traverse with the check engine light being on and the two codes P0008 and P0017 being stored.
The car has about 18,700 miles on the clock. Took it the dealer and they claimed to have cleared the codes and that they couldn't replicate the problem. They also said the 'engine oil was dirty'. The oil only had 3300 miles on it and I mostly do highway driving (changed ever 5K miles). So I had them change the oil and claimed this problem was resolved. Within 5 minutes of picking up the car, the check engine light came on again. Pulled my code reader out of the glove box and again the same 2 codes. Went right back and told them about it but I haven't returned it to be checked out again yet.
I know that the Acadias and Outlooks had timing chain issues that caused this type of problem but I would have thought this issue should have been resolved by the time the Traverses were released in late 2008. The car has reduced power and the gas milage has decreased by about 15-20%.
And with a bit of further internet research I found a document, PIP3423B, that doesn't list the Traverse but all of other GM models with the LLT LP1 and LY7 engines. Here is an excerpt from the document:
Condition/Concern: Vehicles with 3.6 LY7, 3.6 LLT or 2.8 LP1 may exhibit DTC P0016, P0017, P0018, P0019, P0008 or P0009.
Recommendation/Instructions: The reluctor for the crankshaft sensor pressed on the crankshaft may have moved. Refer to attached photographs for exact location. If the reluctor has moved then replace crankshaft.
Has anyone with an early model '09 Traverse had a similar problem?
