1 - 2 of 2 Posts
Hello everyone, so I purchased a 2019 Chevy Traverse High Country, and I've noticed that when I'm using the SXM radio I can't tune it (by manually putting in the channel numbers or by scrolling through the stations) above channel 235, when I contacted Chevy, SXM, and a local dealership they all tell me this is due to limitations in the hardware. I guess this is an xm radio hardware, not sxm radio hardware.
Has anyone else run into this, or come up with a work around other then the standard answer I've gotten which is: use the app.
Thanks in advance.
The fact that you can't tune it manually makes me suspicious of "limitations in the hardware". I will check later today in my 01 if I can do it.
1 - 2 of 2 Posts
