1 - 7 of 7 Posts
My '18 Premier has started to alarm "Shift to Park" when I try to shut down.
The shifter shows "P", and I've been able to shut it down by moving the shifter
down and up, (so far).
Lots of threads on that here. Fix is a new shifter (don't let them just replace the wiring harness). Do a search and you'll find lots of threads on this.
Call and make an appointment with your dealer.
We, as many others, have had to deal with this and eventually the shifter will not budge & will leave you stranded.
It really depends on the dealer you bring it to.
They knew about it in early 2018 and have adapted there repairs through time.
I have attached all the service bulletins (plus part sheet) I have. Print and bring them with you along with any video or pics of your DIC stating "Shift To Park".
Good luck and let us know how it goes...
Discussion Starter · #4 ·
Unfortunately, we're traveling and are in South Carolina. Fortunately, we're towing the car behind the motorhome, and will be heading back to Michigan soon.
Thanks for your help. I'm calling now.
My 2018 is in the shop right now for this issue. They are fixing the Shipper & Jumper Harness. I will post after I get it back to let you know ow if it fixed the problem really.
Discussion Starter · #6 ·
It looks like the dealers are familiar with the problem, so you should be good.
1 - 7 of 7 Posts
