This post is my reply to another forum member who inquired me on how I installed my ScanGuage II on my Chevy Traverse. I didn't know how to attach pictures in PM so I opt this as my answer will benefit others who may be interested.
The ScanGuage is a nice gadget that besides read & reset ODBII codes, it displays many engine-related parameters. I have a Traverse LS without the trip computer on the LT & up. My Scangauge tells me my fuel economy and gives me ways more. In my case, I found the coolant temperature, fuel tank level (% displayed as opposed the fluctuating dash needle) to be extremely useful.
To answer the forum member's specific question, the gauge does display the engine oil pressure. I don't have the oil pressure programmed but I can check it out later next week. To enter the codes is extremely tedious. Because between looking at the sheet of alpa-numeric digits, keying with just 3 buttons (constantly scrolling and move next) with steering wheel in the way, and the unit is trying out shut off after a few seconds of inactivity (it only stays up constantly is when the engine is running), I have enter the same code numerous times just to get it right. It is best to do outside with the engine running and a 2nd person reading the codes while you are entering them...
I installed the gauge on top of the steering column with the supplied Velcro tape and I looped the cable around the steering column. Originally I tucked the cable into dash trim (the cable is partially concealed). If you look at the 3rd picture on how I run the cable, you can push the cable between the gap of gray dash and black trim-piece/wrap on the steering column. I removed it when I took my car to the dealership and didn't want them to see my gauge and haven't spent the time to make it look nice.
The original msg to me read:
Hello lxc,
I am wondering if you have "updated" your ScanGauge II to include the XGauge Features i.e. read here:
http://www.scangauge.com/support/xgauge.shtml
I ask as I would love to know if the ScanGauge II with this new software can actually state oil temperature and oil pressure as is now says it can for GM vehicles.
Any chance you might be able to check this for me? [Supposedly the newer ScanGauge II includes this update but older ones can be updated]
Anyways, just wondering.
[name withheld]
PS I am curious as to where you specifically mount your ScanGauge in your Traverse? Any chance when you have time you could snap me a picture of its setup?
