Offline
Re: rotating tires/recalibrating
« Reply #1 on: November 17, 2010, 12:27:06 PM »
Quote
You have to go into the cal mode....
1-set parking brake
2-turn ign switch to ON/RUN with engine off.
3-press the remotes LOCK and UNLOCK buttons at the same time for about 5 sec.--- the horn will sound twice to signal its in relearn mode. and tire learning active will be seen in the DIC screen.
4- start with the drivers side (also note that the turn signal lamp for that front tire also turns on).
5- let air out-- or put air in for about 5 sec or until the horn chirps. (may take up to 30 sec)-- once it learns that sensor it will chirp..
6- proceed to the front right tire-- repeat- (the light turns on to indicate which tire to get to next).
7-when the last tire is learned it will chirp 2 times.
8- air up tires to proper spec.
Yes, I'm just wondering if this instructions works for a 2010 traverse? I'm planning to do my own tire rotation for the next couple of days and trying to do my homework before doing this job. I heard about the TPMS for the new cars and its not like changing tires like the old days so I am in the process of looking for instructions. If anybody could help, it would be much appreciated.
