1 - 8 of 8 Posts
Where is it?
I did a search on Washer fluid, and all I found was the old "Heated Washer Fluid" topic.
Does the Traverse use the reservoir in the engine bay for both the front and rear wiper fluid?
tks. in advance.
Yes- uses the bottle from the engine bay.
But, I believe the feed line for the rear is located higher on the reservoir so you run out in back first - used as an indicator to warn you that you are low before the front is out.
If im not mistaken- the DIC will also warn you with a "Washer Fluid low- Add Fluid" message .
This is correct. It even does this for my now "ancient" 2004 truck.
The rear washer feed is mounted higher so as not to drain the jar and leave the windshield unattended, when the need arises.
Bob
Discussion Starter #7
Thanks all for the help. This is what I thought was the case, but wanted to make sure before winter hit here. Have to go grab a gallon or two of Washer Fluid for home.
1 - 8 of 8 Posts
