How on earth do you replace the rear wiper blade. The manual says to pull the wiper arm out, but here is the problem. It only pulls off the rear glass a little over an inch by design. So the question is how do you pull it up further or is there some other trick to doing this.
Has anybody lifted there's lately?
Would love any help
Thanks
John
If you lift up that black cover ,there is a nut under it.take the whole thing off and then you can replace it.
just did it the other day the rear wiper is the easy one it has a snap in blade pull away from window reach in where it attaches to the wiper arm thee is a little tab push it in and pull the wiper down and bada boom bada bing its off snap the new one in and your done.....
How is it that the rear wiper needs replacement so soon? All your Traverses are 2009's, they shouldn't need replacement YET. I'm still on the original wiper blades, front and rear, at 22 months and 11K miles.
