Does any one have a problem in cold climate with the rear suspension make a bottoming out sound when you go over a bump?
I had the same issue last winter, I'm located in Canada MB. Went to local dealership in the end of March and got answer "cannot recreate the problem" But they agreed to check my car again in next late fall (when probably will be again cold)...David Mayo said:Does any one have a problem in cold climate with the rear suspension make a bottoming out sound when you go over a bump?
