1 - 15 of 15 Posts
Anyone have any tips on replacing rear ac condenser and expansion valve or anything else to change while I’m back there? I’ll be doing this on Saturday. Seems fairly straightforward but any pointers are appreciated.
Thanks!
the video I see on Youtube. Theres a little filter back in the line that can get clogged.
Similar Issue?
Thanks!
What are the symptoms? Our 2009 does not blow cold air in the back.
Thanks!
Same as you. Front ac works rear does not. I’ve tested rear actuator and it’s working so I figure it’s clogged. I bought condenser, expansion valve and orifice tube to cover all parts while I’m back there.
I ended up starting the repairs today. So far the only part I got my ass kicked was removing the heater core lines. Gonna buy new plastic tabs. Otherwise everything else has gone well so far.
Discussion Starter #8
I’ve already gotten everything put back together and I’m vacuuming the system. Do I need to add pag oil after replacing the rear evap core or the expansion valve?
Discussion Starter #10
I’ve had it back together and recharged since Saturday. Been driving for a few days and everything is still blowing cold front and back 😁
ahhh look at that little filter.
do you know what that stuff is?
Im thinking that it could be a sealer of some type.
Do they sell Cans of recharge/sealer?
1 - 15 of 15 Posts
