My radio does not go off when I remove the key from the ignition and open driver door. Is there something that needs to be oiled or cleaned?
I am having the same problem. I have found if the radio does not always shut off opening the drivers door. I open and close the drivers door several times until the radio shuts off. Just started researching this but have not found the answer.
I'm guessing the switch on the door is sticking. Do your overhead lights come on when the door is opened? I believe they both operate from the same switch.
