2011 Traverse. 357,000 miles (90% open highway). It has started using oil but there is no change in exhaust or performance.
I have noticed that when I remove the oil filler cap, the oil filler tube also comes out sometimes. I am worried that the oil filler tube is not fitting tightly and maybe oil is seeping up through the tube and leaking under pressure.
I have noticed that the oil filler cap can be difficult to open when the engine is hot --- I figure maybe the plastic expands.
I am going to experiment with only opening the filler cap when cold, and also applying oil to the screw threads on the cap to keep the oil tube in place. I will monitor the oil usage and see if this makes any difference.
Does anyone have additional suggestions? Thanks!
