1 - 3 of 3 Posts
How to check power steering fluid level of Traverse 2010....and should the car be driven for some time and then to check steering oil level or if in the morning i have opened its reservior then it is ok...
What engine?
Typically the power steering reservoir is under the main plastic cover in the engine. Take off the oil cap, pull off the plastic cover and you should see it sitting underneath.
You should be fine to check the fluid in the morning, vehicle does not need to be driven or running like transmission fluid levels.
Sent from my SM-G965U using Tapatalk
I check the fluid level in the morning after everything has cooled since it's ATF.
  1. Open hood
  2. Remove oil cap
  3. Remove engine cover
  4. Remove power steering fluid reservoir cap
  5. Clean built in dipstick
  6. Reinsert cap
  7. Remove cap
  8. Check level
  9. Add or suck out fluid as necessary
1 - 3 of 3 Posts
