Pcv valve replacement
53697 Views 42 Replies 16 Participants Last post by  greentraverse
My 2011 has 130000 Miles on it now.i was planning on changing the pcv valve and was curious if anyone has done this.im also going to drain coolant and transmission fluid.i changed plugs at 105000 and drained transmission fluid but only got 4 quarts to drain so I know it needs it again.it runs as good as new and I would like to keep it that way.any info would be greatly appreciated.
41 - 43 of 43 Posts
Question: When replacing the spark plugs in my wife's 2010 Traverse, I consequently lost the PVC 90 degree fitting that goes directly on the top of the intake manifold (you can see it prominently when you remove the plastic engine cover). The fitting goes to a rubber hose that goes to the rear of the engine, near the firewall. What is this fitting called, and does anyone have a part number so that I can order it?
You can find one in the junk yard
Is this it?
41 - 43 of 43 Posts
