1 - 1 of 1 Posts
does anyone know the OHM specs on vvt actuator (12 enclave 3.6)... i replaced timing chains, guides, tensioners. had to replace 1 exhaust valve on cyl #2 due to spark plug breaking apart and took a chunk out of one of the exhaust vavles. lapped in a new one and have compression again... engine starts, idles rough. seems to run good off idle.. im getting a P0019 code. pulled actuator and its clean, looking for ohm specs..
thank you
GB
1 - 1 of 1 Posts
