What have you done so far to research the problem and diagnose cause of the code. Do you have OBDII reader? Any other problems or codes. Do you know the history on the vehicle?
[/QUO
No the only code I am getting is the p0017 bank 1 sensor B but when I first bought it had a cat code replaced cat and was fine other then that good
Do have any drivability problems, hard starting, rough idle, surging, stalling, or noise from the engine?
I know after I reset it it came back on after 400 miles but I have notice when its idling it drop rpm and then will pick back so guess it stalls for little bit but come back to normal
