1 - 10 of 10 Posts
for any of you northerners have you seen your temp readout dip below 0degs mine just stays at zero and wont go any lower....
All the time, when it is suppose to be below 0 degrees.
The day before it was -11 F but I didn't drive that day, my wife did so I didn't see the temp. We played a game that day and it was 0 in the rink. The kids were frozen by the end of the game.
Discussion Starter · #7 ·
ok thanks guys..sounds like mine maybe sick.
I've seen my temp gauge stick for a short time. When I got in it to go to a store a few weeks ago, the weather was turning bad and the temp was dropping fast. When I parked, it was still just below freezing at 31. When I got back in, the temp was still 31, but I knew it had already dropped almost 10 degrees outside. After about 2 miles of travel, the temp gauge suddenly started moving downward quickly. Within another mile it was under 20 degrees like it should have been. I haven't seen this happen again, so unsure if it was a temp monitor hardware issue, or a software issue.
Ive seen mine exhibit this behaviour...
I know its colder- but the temps displays a higher temp---
(I have always seen this from cold startup)...
Eventually the temp changes...
But I have noticed that sometimes the temp adjust very fast-- other times- its like it take its time to update...
1 - 10 of 10 Posts
