My first post... and first oil change so I figured I'd make it useful with pics. There are in no specific order.
Changed @ 599 miles because of all the crap I read about how the oil is black. Oil was no black in my case... looked like it could have used another 2K miles put on it but it does not matter... good learning experience and I put a good filter w/ full synthetic in.
Most important in this whole process to take away is that you have to be careful when you maneuver the filter up when you unscrew it. Half of it was full with oil and lucky for me I made sure that my arm & hand was in a position to tilt it up-right after it was unscrewed and I could pull it straight up. Thankfully I didn't spill anything, but I can see how things could have gone really wrong. The position of the filter is so retarded that you can easily drop it and splash everything everywhere.
Aside from that, the rest of the change was easy and not a big deal. In fact, in some ways it's easier to change then my other car... Xterra. The nice thing about this filter layout is that below the filter is a little shoot that the oil travels on. Most other cars, the oil travels right along the filter and then you get all your filter is covered in oil. This however (if you don't drop it) will allow you to take the filter out dry.
I don't know how long I'll have these pics up.
Took about 45 min. Will probably take about 25 or 30 next time now that I know what I'm doing and filter is on hand-tight only.
Cheers.
Chris
Cheers.
Chris
