Hello All,
Sorry if this has already been addressed before. I recently purchased a used 2019 traverse LT with only 26k miles. Did the necessary due diligence before buying the car. However, I started to notice a vibration right after the car shifts from 1st to 2nd gear and another one when it shifts from 2nd to 3rd. Seems to occur only when I am driving with normal acceleration and when the rpm goes down after shifting. The vibration gets rougher as I drive more in the city (more acceleration and deceleration). Its as if the car is not sure what gear it should shift to. This symptom is not seen at high speed, subsequent gears or during hard acceleration.
No error codes, no engine lights and no upnormal sounds or smells.
I drove the car with the transmission on L and started to manually shift with the +/- button and the vibration was gone. Seems that if the shifting is done by the driver instead of the transmission, the hesitation and vibration issue no longer presist.
Appreciate your guidance if you have ever come across this problem before.
Thanks
Thanks
