1 - 11 of 11 Posts
I replaced my factory single exhaust from the cat back, with the factory LTZ dual exhaust, so if anyone needs the original factory single exhaust, it's for sale. I have a 2010 Traverse LT. It should be worth $200 but I would accept any offers. It's all one piece from that 2 bolt flange after the horizontal cat converter and includes the rubber donuts. I live in southern California.
Legend - Just curious, what did you do to create the cutout in the rear bumper cover for the second tailpipe? Also, any photos of the new install?
andylibby said:
Legend - Just curious, what did you do to create the cutout in the rear bumper cover for the second tailpipe? ALao, any photos of the new install?
I was curious to see how you handled the second tailpipe as well.
I just carefully cut out a little at a time with some right and left angle tin snips and a box cutter as I lifted the dual exhaust up and down with a motorcycle lift, to try it after I attached the front end. It came out looking pretty good. :cheers:
Thanks! Now, if only you'd had the engine output measured on a dyno before the swap. Then you could have a before and after horsepower comparison.
As it is, I would hope you might experience a bit of improved fuel economy, but I'm wondering if the decreased backflow afforded by the dual pipes will affect other facets of the vehicle's programming and setup. Have you noticed any differences?
Seems to have a bit more zip and takes off from a stop easier. My wife says so too. Should be the same hp and torque as the LTZ now. It is the fastest vehicle for it's size and weight I have ever had.
Where did you get the dual exhaust and how much did it cost? Was it easy to install?
i spoke to my service manager at the dealer and he told me for the effort the 3.6 would benifit from an air intake over doing the dual exhaust. i am already working with a friend on a possible upgrade
I don't think the stock dual exhaust buys you that much. Have you seen the area where it "Y"'s out? It's like they collapse two tubes on each, to fit into the single pipe. Talk about a restriction!
I'd prefer a true free-flow muffler, with a smooth "Y" transition, with the option of resonated and non-resonated with single or dual-tips. :thumb:
I've lobbied Billy Boat Exhaust www dot bbexhaust dot com, but they don't believe there is significant market for aftermarket exhausts on the Lambdas...
Hmmm, maybe a "Group Buy" would get them to change their mind. I mean, if they make it for the Escalade, which is lower volume, I think they could really make some $ on the Lambda platform.
XRDreamliner,
I'm with you. Here's where some true gains can be made. Straighten all this flow out just around the motor and THEN you will see some improvement.
Jim
In God We Trust!
New here. Have a 12 AWD Lt and was thinking of cutting single exhaust out at converter and doing a dual swap myself. I'm looking more towards performance/sound. Planning to build system with high flow cat an single in dual out muffler an dumps rather than tips an bumper mod/swap. Any thoughts?
1 - 11 of 11 Posts
