1 - 3 of 3 Posts
I love the traverse but if you use the 12 volt socket on the console you block your cup holder. I use mine for my GPS so it's always in use. Has any one added a second socket to front console. How does the cover come off so I can come off parallel to the existing socket. It sure appears I could put one on the driver side so I could have the GPS plugged in under the dash.
there is someone on line that sells a small plug that you can use to tap into a switched 12V power source that is located at the back of the rearview mirror. (if you have Onstar).
ill try to find the link...
but you may want to go that route by tapping into that KNOWN switched power source and running the cable to your GPS>
Remember, there is a plug in the back of the console for the 2nd row seats too. You might try that one and see if your cord is long enough to get what you need out of it.
1 - 3 of 3 Posts
