1 - 10 of 10 Posts
Need help removing the PCV valve. As I was twisting the stem part, it sheared off and left piece in the hole. Is there another way to remove?
10364
Thanks.
See if you can get a screw in where the threads can bit into the plastic then try to yank the screw out. Otherwise you will probably have to pull the valve cover.
hard to tell. this the metal part?
what year?
look at post #25. someone used a trim removal tool to lift theirs up.
Discussion Starter · #6 ·
Yeah, looks like I'll have to remove the valve cover.
No need to do a reset when pulling a valve cover.
Discussion Starter · #9 ·
@repairman54, @rbarrios, and @cintocrunch thank you so much for your help!! Looks like I'm getting closer to fixing the P0171 error code. Now it makes an off and on hiss sound but after driving the car for a while. Also noticed when I let go of the accelerator while driving the STFT1 and LTFT1 jump to about 35 then it's corrects itself. Also the RPM bounce when applying the brakes but not all the time. When its been sitting and cold start it will not make the hiss sound when started. Sounds like it's coming from the intake hose close to the throttle body side but do not see any noticeable damage. Sprayed liquid on there but do not see anything. Should I be looking at a certain reading on the ODB2 scanner? Thanks.
Sounds like you may have a crack in the plastic intake tube. I'd pull it off and check it, the material used doesn't keep its flexibility forever and the accordion section has been known to crack on many vehicles.
1 - 10 of 10 Posts
