My daughter owns a 2014 LT AWD with 160000, the car had a Misfire code on cylinder 4, I am writing this because when she drove it to the local dealer for a diagnose the service writer quoted her a new engine $7000 and some change, she said it took them about 30 minutes to come up with that. (What a rip off), so I started the troubleshooting, 1st Sea Foamed, thought sticky valve, (No Change). Changed coil, (No Change). ran compression check (Bingo). dead cylinder.
Pulled: Intake, Exhaust Manifold, Both Valve covers, timing cover and all associated with that, all 3 timing chains, and finally found that the intake valve was burnt. after installing new valve and removing and cleaning all in that head started reassembling, installed new: Timing Chains, oil Pump, Water Pump. Plugs of course all new gaskets, believe me I did this all with the motor remaining in the car. I don't have a car lift, and yes not going to lie. it was a pain in the ass! but I just couldn't see the daughter take on that much debt, total cost (Parts) $450. ish..
