1 - 3 of 3 Posts
Can anyone recommend a replacement Mass Airflow Sensor? The Delco is $325ish and you can get aftermarket for $125 and even re-manufactured for $85 bucks! I've had the hesitation under load problems and have replaced O2 sensors, some coils, plugs, ran several tanks with techron etc. My 2009 has 160k, uses oil, valves are probably dirty but looking to squeeze out some more miles.
Delphi is what I have used before for a MAF replacement. It was on a different vehicle, but has worked for probably 6 years without any issues, as the old one was throwing a code. Rockauto is a site which gives you many options for parts, it is pretty much what I always use unless I can find a reasonable source locally.
1 - 3 of 3 Posts
