1 - 3 of 3 Posts
Does anybody know the bulb size of the license plate lights? One of them died and I want to replace them my self and I don't know how to take them out.
Is there an LED replacement bulb for them?
Here is the GM procedure to replace the bulb:
Remove the retainer that is holding the connector or slide the connector end off the retainer from the inside of the rear bumper fascia.
Use a small flat bladed tool to release the license lamp assembly from the inside of the rear bumper fascia.
Replace the bulb as necessary.
Tip
The release tab is located on the forward side of the lamp assembly.
I bet this would be more helpful while looking at the bumper. The bulbs are a 194 and you can go here to find LED's
http://www.superbrightleds.com/mini-wedge.html
Thanks! I got the light bulb out. It was easy to remove. I replace them with LED white. They look nice!
1 - 3 of 3 Posts
