1 - 13 of 13 Posts
Hi,
I frequently receive this warning message that my left front tyre needs air.
When I take it to the workshop, I find nothing wrong with the tires. Actually it was the front right tires needed air in the last two times I checked that issue..
Last week I made tire rotation replacing rear tires with front ones. Surprisingly, two days ago I received the same message again..
Not sure if right or left depend on if you are sitting inside the vehicle or outside ..
Besides how come I am having this issue without visibly seeing any issue with the tires..
By the way, the tires are Bridgestone and bought them less than 3 years ago.
Any ideas why this is happening?
Sent from my SM-N960F using Tapatalk
Generally it happens if you have interchanged the tires or tire rotation has been done. So may be this is one of the reason
You don't say what model year you have. If it's an early Gen 1, you can re-learn the tire sensors to the tires easily; there's a description in the owners manual (Pg 10-49 for 2011, "TPMS Sensor Matching Process"). If you have a later Gen 1 (2014 and later, I believe), or a Gen 2, you need to buy a cheap relearning tool.
See here:
OR do what I do: don't sweat which tire - just check all the tires when the pressure message comes up.
AND - It's normal for this message to come up as we go into the cooler weather of fall/winter, BUT if one of the tires needed air twice, then I'd say you have an issue with that tire.
2020 Traverse LT
You could also have a bad TPM (tire pressure monitor)....those are on/in the valve stem. They do go bad, you should replace when changing tires. Plus make sure your TPM programming is current.
The problem is I was having the same message for the same tire before and after the tire rotation..
See here:
I have Traverse 2012.
Actually, I do check all the tires when I get the message. What seems funny is the the message says the problem with my front left tire. When I check the air pressure for all tires, I find the front right tire has the lowest air pressure!!!
The same issue is now after doing tire rotation. This is confusing really.
Discussion Starter #7
Does this happen even when doing tire rotation?
With a 2012, you can re-learn the tire positions yourself. I'd do that, and see what happens. If the tires have been rotated but never re-learned, then the DIC isn't going to match the tire position.
Discussion Starter #9
That is correct. I'm afraid the tires have not been relearned after the rotation.
Will do that and post the update here.
Discussion Starter #10
Guys, just to update you on this subject.
I took the car to a dealer service. The sensors are ok. They relearned the sensors and found the "guilty" tire
If the warning comes up again then there is some serious issue with it.
Thank you for the help all.
its that time of year...
I get someone elses onstar report.. so I know his tires are low on air. Just got the email few days ago.
(his name is the same as mine- and bought a car at a dealer Ive used- so they must have crossed names/emails)
Also- just this morning at 5 am, guy I see eveyday pulling out of driveway- saw/heard him using one of those noisy electric air pumps to air up a tire- the kind you plug into cig lighter.--- which im sure his DIC said was low
Several weeks ago, I adjusted my cold tire pressure to 36.
Now that its cooler, when I roll away, tires are at 35 PSI... pretty soon ill adjust again as mornings get cooler
I found out a couple of months ago that a low battery in the TPMS sensor will give a false alert, also.
1 - 13 of 13 Posts
