Is this a good enough socket to do the job?
229 Views 6 Replies 4 Participants Last post by  repairman54
I am planning to change the O2 sensors. Is this socket good enough to remove the sensors off the vehicle? I have heard that some sockets are not strong enough and rounded the sensor nut instead. Thanks.
1 - 7 of 7 Posts
3
Yes thats good. Exactly what I used.
I believe theyre called crows feet.
If rust belt, youd prob want to spray penetrating oil overnight.
im in california. I didnt have to spray them.
Pic of 3 of the sensors. Cant find 4th pic.
Change done at 100,000.
Was having no issues with them. I just do it as preventative maintenance.
See less See more
It also helps to attempt removal while the exhaust is still hot.
Thanks gentlemen.
@rbarrios , it seems your socket has a double square head for the ratchet drive square which make it easier to maneuver. The one from Rockauto just a square.
@Watthour , thanks for the advise. I will make sure I warm it up before attempt to remove the downsteam sensors.
Hood Automotive tire Automotive fuel system Automotive exhaust Motor vehicle
See less See more
interesting on that socket
The pic with the red arrow, thats ratchet from up top going down, and im under the car snapping the pic looking up.
2
Yours looks like the OEM brand and the one that Rockauto carries is Performance Tool. The PT seems shorter on height and thicker on the socket wall.
Camera accessory Camera lens Font Rectangle Cameras & optics
Camera accessory Font Auto part Household supply Fashion accessory
See less See more
I've a similar one for 25 yrs now. I think it's an OTC brand. I've had breaker bars on it and still hanging in there.
1 - 7 of 7 Posts
