The instrument cluster in my 2010 Traverse went out while I was driving it. All the guages/lights went dead, I heard a soft “ppfhth” sound, and smelled electrical burn from somewhere behind the instrument cluster, so something shorted. Car works in most other respects (ODB port doesn’t work, and neither does the key fob). I ordered a replacement (used) instrument cluster, but that did not fix the problem. I removed the BCM and sent it in for repair. The repair service said they found a fault (unspecified) and repaired it and sent the BCM back to me. After re-installing the repaired BCM, the problem was not resolved. Neither cluster worked. I have checked all the fuses (under the glove box and under the hood), and I can’t find one that’s blown.
any ideas?
any ideas?
