Since I had my air filter out- I decided to check the throttle body- and check for oil in the tube.
Yup- found some oil. not alot- but there was some.
With the air filter cover out of the way- its easier to work this area.
I used tissue to absorb the oil accumulated here. There a catch basin- where it pools. Kind of like- its expected and this is were it goes.
If youve did not remove the air filter box- youll want to loosen the screw that tightens the band. I also disconnected the wires to the sensor. (****NOTE at the bottom*****).
Youll also want to disconnect the small tube (where the oil appears to come from).
loosen the 2nd screw closer to the throttle body. and remove the assembly- you can then clean up the oil better.
You can also see the MAF sensor. Note that when removingthe parts- is when dust/dirt is loosened. But overall the inside of the tubes are clean.
NOTE-- it is my understanding- that the following needs to be done WITH BATTERY DISCONNECTED...OR the KEYS OUT OF THE IGNITION.
so you cant be listening to your car radio... you dont want power to the throttle body- do LEAVE THE KEYS OUT OF IGINITION.
What we want to do, is clean the moving part of the throttle body. the flap that moves.. I sprayed the cleaner on the moving part-- and then moved it a few times to get the crud off. Then I gently cleaned the area.
the dirty throttle body.
then reverse to put back toghether. When you try to start- youll notice it cranks longer- and may stumble. This is due to the stuff that was sprayed in.
*******NOTE--- After I did this - I heard my fans running.... I dont know if its because I was directly over the radiator and I could hear the fans.... or because I disconnected the plug to the MAF.... Im trying to get info on this. .....
