1 - 3 of 3 Posts
My friend has a 2016 Traverse and needs to change the headlight light bulb. I thought it was as easy as turning the wheel and removing the inner plastic fender shield. Is that all it takes, or am I missing something?
Yes. But if you have big hands like me, the opening is a tad small. One big tip is to wear latex or Nitrile gloves when handling the new light bulb. You don't want oils from your fingers transferring to the light bulb. I didn't have gloves, so used a paper towel, which was a little awkward, but worked. Also use a little dielectric grease on the contacts.
1 - 3 of 3 Posts
