If you have a Traverse-- or Outlook/Acadia/Enclave and have the factory tow option- then these directions are for you.
If you dont have the factory tow option- then youll have to figure out how to wire up your lights.
I originally made this rack for my 03 Trailblazer. I once used the rack on a long 3200 mile trip (no lights). On the trip I was always concerned that I would get rear ended or someone would not see the rack in the dark and get too close and bang.... So I opted to add LED lights for the next trip.
You can add the old style big square box lights--- but these are slim- and when on the LEDs are BRIGHT!
The rack I bought- is available at Harbor freight. Usually on sale for $50-$80.
This rack will become so valuable-- its a great bang for your buck. I use it to carry cargo on long trips--- but more often I use it to carry stuff that can leak in the interior of the vehicle.
On the Traverse--- the factory connector is referred to as a Round 7-wire. (The 4-wire plug is called a Flat 4 and WILL NOT plug into the Traverse w/o using an adapter.
Here is the connector I ordered-
http://www.etrailer.com/pc-TEC~H20042.htm
I bought the LED Slimline Stop, Tail, Turn Light with Reflectivity (they also have the NON reflective) but for a few more bucks-- why not add have the reflective ones....
http://www.innovativelight.com/slimline-stop-tail-turn-light-with-reflectivity_p_1477_11598_10.cfm
Here are the lights as they are delivered.
I wrapped up the LED lamps wires with Electrical tape. Simply to make them neat
Note that the lamps have a small stub where the wires come out of--- on my rack I drilled a hole to allow the lamps to sit flush with the metal.
I also drilled small holes- where 2 small nuts/bolts will be fastened to hold the lamp in place (for left and right side or rack)
Here I mounted. added more color coded wire (to add more lenght) soldered and shrink wrapped the connections. I then wrapped all the wiring up to make it neat.
Here I have both sides installed and I zip tied the cables to the underside of the rack- I did this because I dont want loads putting weight on cables and possibly pinching them while in transit- As you can see theyre wrapped in electrical tape and neatly zip tied so that they dont hang- and possibly get snagged by roadway debris.
Here I am making the connections to the 7 way connectors wires.
Also note that I tied off and covered the wires from the 7 way connector that I wont be using in this application.
I believe the factory connectors door- has an image of what the pins are for.
Here the wiring has all been wrapped in electrical tape- all wiring is zip tied underneath and as close to metal where it can be protected from road debris. Keep it neat. (before you wrap it all up- use a meter to check for continuity- for example- that a green wire at the beginning is still a green wire at the end)
Here is an underside shot of the factory hitch- (im laying down- looking up)- with the rack installed and the 7 way connector plugged in.
when you lift the tab on the factory electrical connection point--- the 7 way connector will only plug in 1 way- as there is a tab on the connector .
Also- with the lid open- there is a tab on it and on the connector- that holds the cable on place. it wont come loose until you lift up the tab and pull the cable.
Here is a side shot of the rack.... please note that I added red/white reflective tape...
Why? At night- drivers cant see the black rack- so for safety- I added the reflectors. I believe Wal Mart is where I bought strips of these- in the towing section.
Here is a night shot- of the brakes applied on my Trailblazer. (Couldnt wait for nightfall to take pics of the Traverse with rack).
The LEDS are bright--- especially for traffic directly behind you.
Like said- these LEDs will signal left and right. stop (brakes) and will turn on with the driving lamps. They also flash with your emergency flashers.
These are just the PARKING lamps... nice and bright- Note the Upper 3rd brake light is off.
