Anyone know how many gallons this Traverse holds? I just put 22gallons in it and had to be near empty.
My Acadia owner's manual says the tank is 22 and I know I've put at least 20 in it. The info below is pasted from the 2007 Acadia owner's manual.medicrxdoc said:Since the tank is 22 gallons, it is larger (Acadia's have only 18 or so). I wasn't able to find a picture online.
Acadias are 22, all of the lambdas are 22, and they are all designed the same.medicrxdoc said:Did anybody with less than a 1/4 tank try to start on a steep incline withe the nose higher than the rear? On the Acadia's, the gas tank is long and slender. With the design, when you are low on gas while on the incline nose high, the fuel pick-up is unable to suction any fuel and it can't be started. Might be a good idea to take a look at the design so you guys don't have any problems.
At least you got the max discount them.stumpk said:that gas was from Kroger w/ my perks of $.50 off per gallon. $2.85 was the original price per gallon.
Good. Then I have a few gallons to spare then.....ok, maybe I won't push that envelope.khansen30 said:Acadias are 22, all of the lambdas are 22, and they are all designed the same.
How is possible to put 23.2 gallons on a 22-gallon tank? On a different car?ramjet said:My first fillup was 23.252 gallons, on a stretch of the PA Turnpike in which a service plaza was unexpectedly closed. I was sweating bullets.
