1 - 3 of 3 Posts
I recently got a 2011 Traverse LS, which came without a backup camera. I bought an aftermarket camera and am ready to install. I need to find the wire that goes to the backup (reverse) lights mounted in the rear door. This should be a 12V power source that will activate the camera when the vehicle is put in Reverse. There are about 20 wires going in the direction of the rear door that I can see in the rear access panel. Does anyone know which color wire goes to the backup lights?
Thanks for your help
Try accessing the reverse light and see which wire goes to the bulb, then try to find it in the harness . to be sure if and when you find the wire use a test light to make sure it is the same wire.
1 - 3 of 3 Posts
