1 - 9 of 9 Posts
I recently had the privilege of installing a new low beam bulb. I broke the clip that holds the bulb in place. I just couldn’t get both hands in there and see it at the same time. Will there be issues of it coming lose later on?
i guess it depends on exactly where it broke.
the bulb has tabs where the plug clips on to....
heres what the bulb base looks like
Discussion Starter · #4 ·
It was a small black piece with an opening in it. Since I couldn’t see exactly where it was I just figured it was on the wiring harness.
Sounds like it was the locking tab on the harness side of the power connector.
Usually the rubber water seal on the plug will hold it in place. I've had locking tabs break off in the past myself. If it does loosen just wrap tape around it like Superdave said.
1 - 9 of 9 Posts
