1 - 10 of 10 Posts
I recently bought a 2010 Chevy traverse and found a ground cable under the air intake box that is not connected.the cable in question is located just above the wiring harness ground and runs down and forward toward the front of the engine compartment....any clue of where this wire should be connected?
a picture of the wire would help.....
I will try to take a look when I have access to my Traverse. Thanks for pic.
ok, based on the location of the cable under my air box, and the white decal/tag on the cable, and the connector end on the cable.. this is what I found,
I used a little mirror to look at the cables end- and the white tag attached to it
You can see the thermostat hose, the heat shield, etc. You can also see the ground cables black heat shrink.
Should let you easily find where it connects.
You didn't mention any performance issues with this "loose" ground.
Find that really strange.
Wonder why it's even there?
U recon GM just had some "loose" grounds(pun intended) laying round and just pitched them in that model Traverse?
They've done some really strange things in the past..........OR, do U think Ford crept in the middle of the night and?????.
Took the time to go out there, trace wiring, take pics, upload pics to filesharing acct... and make the post...
and he never came back.
Guess Ill be wary of 1st time posters
:mad:
Hello Robert, it’s been some time, happy to see you still on the site.
Recall you and I made our purchases close it time.
My ‘09 has fallen way behind you, only at 102,000 miles.
All is well.
AHHH! Good to see you on the site.
Yup- mine is still going!
Burning oil- but still going;.
1 - 10 of 10 Posts
