Hey there should be a way to enable the address change while in drive. Normally these safeguards work by adding a negative or positive charge to one of the system wires while in park, thus signaling the system to enable address changes. I have done this a few times on aftermarket systems. It usually involves checking each wire for a current change when the gear is shifted from park to drive and is very simple to do
Does anyone know where to get a wiring breakdown for the Nav system?
