Hello. First time being here and I have a 2012 Traverse and they have 255/65/18 on them. Wanting to go up to 20s and trying to find out if it's possible to do so. Thanks.
If the bolt pattern is the same in the replacement wheel, they can be physically installed. However, I think your real question is regarding tire size, as AlisoBob referenced. Depending on the tire size selected, you may or may not have calibration issues with various vehicle systems--speedometer, odometer, traction control (if so equipped), ABS, etc. The critical aspect is the tire diameter/circumference; it must be the same as the original tire or you will have to recalibrate.
Why? It doesn't really matter though as long as the circumference is the same . Thats important because so many systems depend on it.
